Change History
V1.1.0 (2 May 2017)
V1.0.9 (14 Sept 2015)
| • | USB drivers updated to v1.0.3 (Microsoft Hardware Certified) |
V1.0.7 (21 Jan 2014)
| • | Fixed launch compensation not working at certain speeds with smoothing. |
V1.0.6 (10 Oct 2013)
V1.0.5 (6 May 2013)
| • | Fixed vehicle speed determination method not showing correctly after update. |
| • | If the configuration has been changed, and then the Traction Control unit plugged in, ask the user if they wish to re-read the configuration or keep the current configuration. |
| • | Prompt to write unsaved Traction Control configuration changes when application closed. |
V1.0.4 (30 Jan 2013)
| • | Fixed S2000 sensor type description (passive rather than active) |
| • | Better notification when two applications try to connect to the Traction Control hardware simultaneously. |
V1.0.3 (23 Oct 2012)
| • | Don't start datalogging if the Traction Control is switched off (allows for burnouts). |
V1.0.3 (18 Sep 2012)
| • | Require registration before Traction Control can be used. |
V1.0.2 (22 Aug 2012)
V1.0.1 (3 May 2012)
| • | Added sensor error counters. |
| • | Changed the error report so that the user is notified if an issue has been fixed. |
V1.0.0 (9 Mar 2012)
