Traction Control Module Wiring |
Do not use 'T taps' or similar to connect the Traction Control module to power and ground.
Power and Ground should be connected to the ECU power and ground (IGP1 and PG1) close to the ECU connector. Alternatively, the ground may be run to the ECU master ground (for Honda / Acura this is normally on the thermostat housing or valve cover).
The Traction Control analog output should be connected to the ECU traction control input (ELD on S300 & KPro, pin varies with FlashPro). If using the ELD pin, remove this pin from the connector and insulate the ELD wire.
Using the Traction Control software Test tab, generate an output voltage to the ECU. Using SManager / KManager / FlashProManager, check that you see the same voltage by datalogging the 'TC.Volt' sensor. |
