Installing USB Drivers |
Install the Traction Control software either from the install CD or by downloading from http://www.hondata.com/downloads.html
Once the Traction Control software is installed it is recommended that you check the Hondata website for updates using the Check for Updates command.
It is only recommended to have one copy of the Traction Control software on a PC at a time (i.e. do not keep multiple versions of the Traction Control software in different directories).
Installing USB Drivers (Windows XP)
