Module Placement |
There are several items which need to be connected:
Traction Control Module The traction control module should be placed near the ECU. If the ECU is under the hood or exposed to weather, the traction control module should be placed as close as possible to the ECU but somewhere dry.
ABS / wheel speed sensors The traction control module needs to be connected to the wheel speed sensors. Usually the best way to do this is to connect to the wiring harness close to the ABS unit.
Switch Module The switch module should be placed where the driver can reach it easily. Please note the switch cable is not a telephone cable, and these will not work. A suitable replacement cable is Assmann AT-S-26-6/6/B-7/R
