Installing USB Drivers (Vista / 7 / 8 / 10 / 11)
Important: Please install the KManager software before plugging in the ECU
1.Plug the USB cable into the ECU and laptop. The ECU does not need to be in the vehicle at this point. When you plug in the USB cable the following message should be displayed:
install-vista-found
2.Vista will find and install the drivers.  If Windows opens the 'Found New Hardware' wizard, follow the instructions for Manual USB Driver Installation
install-vista-finished
The USB drivers are now installed.  If you have any problems installing the USB drivers see USB Troubleshooting
