This command downloads and exports the on-board datalog as a comma delimited text file.
2030 rows (20.3 seconds) are created.
Column headings are:
| • | lf - Left front wheel speed |
| • | rf - Right front wheel speed |
| • | lr - Left rear wheel speed |
| • | rr - Right rear wheel speed |
| • | front - Front axle speed (as determined by the settings) |
| • | rear - Rear axle speed (as determined by the settings) |
| • | speed - Vehicle speed (as determined by the settings) |
| • | slip - Driven to un-driven axle difference (tire slip). |
| • | turn - Vehicle turn (straight = 0)) |
| • | turnadj - Turning adjustment (straight = 100) |
| • | slipadj - Tire slip adjusted for turning |
| • | slipover - Slip over target slip. |
| • | smoothed - Over slip smoothed result or PID result (as determined by the settings) |
| • | output - Output to the ECU in volts |
