Traction control connector, as viewed from the wire side:
March 2012 to October 2012
GND
Black
+12V
Red
Out1
Out2
Out3
Out4
LF+
Blue
RF+
Green
LR+
Brown
RR+
Violet
GND
+12V
Serial Out
CAN L
CAN H
ECU
Orange
LF-
Lt Blue
RF-
Lt Green
LR-
Tan
RR-
Pink
October 2012 onwards:
GND
Black
+12V
Red
Out1
Out2
Out3
Out4
LF+
Blue
RF+
Green
LR+
Brown
RR+
Purple
GND
+12V
Serial Out
CAN L
CAN H
ECU
Orange
LF-
Yellow
RF-
White
LR-
Gray
RR-
Pink
Be sure that the ground is connected correctly. Switching the ground and ECU output is known to damage the traction control unit.
Pin descriptions:
Pin
Connection
Notes
GND
Ground
Connect to the ECU ground close to the ECU. Do not ground to the chassis or ECU case.
+12V
Power
Connect to the ECU power supply close to the ECU.
Out1 to Out4
3.3V pulse outputs
Max load 5 mA. Do not connect to power or ground.
Serial Out
Serial output
0V idle / 3.3V active
CAN
CAN interface
ECU
Analog output to ECU
Provides an over-slip analog signal to the ECU.
LF+
Left front wheel input positive
LF-
Left front wheel input negative
RF+
Right front wheel input positive
RF-
Right front wheel input negative
LR+
Left rear wheel input positive
LR-
Left rear wheel input negative
RR+
Right rear wheel input positive
RR-
Right rear wheel input negative
Common Wheel Speed Sensor Wiring
Most ABS connectors have more than one wire of the same color. Please check the manual for correct wire colors and pin numbers.
Wheel Sensor
Traction Control
1995 Prelude
Left Front +
Blue
Green / Blue
Left Front -
Light Blue or Yellow
Brown
Right Front +
Green
Green / Black
Right Front -
Light Green or White
Green
Left Rear +
Brown
Light Blue
Left Rear -
Tan or Gray
Grey
Right Rear +
Violet or Purple
Green / Yellow
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
1997-1999 Prelude
Left Front +
Blue
Green / Blue
Left Front -
Brown
Right Front +
Green
Green / Black
Right Front -
Green
Left Rear +
Brown
Light Blue
Left Rear -
Tan or Gray
Grey
Right Rear +
Violet or Purple
Green / Yellow
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
1993 Integra
Left Front +
Blue
Green / Blue
Left Front -
Brown
Right Front +
Green
Green / Black
Right Front -
Green
Left Rear +
Brown
Light Blue
Left Rear -
Tan or Gray
Grey
Right Rear +
Violet or Purple
Green / Yellow
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
1994-1997 Integra
Left Front +
Blue
Green / Orange or Blue
Left Front -
Light Green / Black or Brown
Right Front +
Green
Green / Black
Right Front -
Green
Left Rear +
Brown
Light Blue
Left Rear -
Tan or Gray
Grey
Right Rear +
Violet or Purple
Green / Yellow
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
1998+ Integra
Left Front +
Blue
Green / Orange
Left Front -
Light Green / Black
Right Front +
Green
Green / Black
Right Front -
Green
Left Rear +
Brown
Light Blue
Left Rear -
Tan or Gray
Grey
Right Rear +
Violet or Purple
Green / Yellow
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
1996-2000 Civic
Left Front +
Blue
Green / Orange
Left Front -
Brown / White
Right Front +
Green
Green / Black
Right Front -
Green
Left Rear +
Brown
Light Blue
Left Rear -
Tan or Gray
Grey
Right Rear +
Violet or Purple
Green / Yellow
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
2002-2006 RSX
Left Front +
Blue
Blue / Orange
Left Front -
Brown / White
Right Front +
Green
Green / Black
Right Front -
Blue
Left Rear +
Brown
Yellow / Red
Left Rear -
Tan or Gray
Grey / Red
Right Rear +
Violet or Purple
Green / Yellow
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
2000-2005 S2000
Left Front +
Blue
Blue / Orange
Left Front -
Brown / White
Right Front +
Green
Green / Black
Right Front -
Blue
Left Rear +
Brown
Yellow / Red
Left Rear -
Tan or Gray
Grey / Red
Right Rear +
Violet or Purple
Green / White
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
2006-2009 S2000
Left Front +
Blue
Blue / Orange
Left Front -
Brown / White
Right Front +
Green
Green / Black
Right Front -
Light Green
Blue
Left Rear +
Brown
Yellow / Red
Left Rear -
Tan or Gray
Grey / Red
Right Rear +
Violet or Purple
Green / White
Right Rear -
Pink
Blue / Yellow
Wheel Sensor
Traction Control
2004-2008 TSX
Left Front +
Blue
Blue / White
Left Front -
Brown / White
Right Front +
Green
Green / Black
Right Front -
Pink
Left Rear +
Brown
Yellow / Red
Left Rear -
Tan or Gray
Red
Right Rear +
Violet or Purple
Green / Yellow
Right Rear -
Pink
Blue / Yellow
Important: This vehicle uses active ABS sensors.
Wheel Sensor
Traction Control
2009-2010 TSX
Left Front +
Blue
Orange
Left Front -
Green
Right Front +
Green
Light Green
Right Front -
Purple
Left Rear +
Brown
Blue
Left Rear -
Tan or Gray
Red
Right Rear +
Violet or Purple
Pink
Right Rear -
Pink
Purple
Wheel Sensor
Traction Control
2006-2011 Civic Si
Left Front +
Blue
Orange
Left Front -
Grey
Right Front +
Green
Green
Right Front -
Pink
Left Rear +
Brown
Blue
Left Rear -
Tan or Gray
Purple
Right Rear +
Violet or Purple
Light Green
Right Rear -
Pink
White
Wheel Sensor
Traction Control
2012+ Civic Si / ILX
Left Front +
Blue
Orange
Left Front -
Grey
Right Front +
Green
Green
Right Front -
Pink
Left Rear +
Brown
Blue
Left Rear -
Tan or Gray
Green
Right Rear +
Violet or Purple
Light Green
Right Rear -
Pink
White
Connector pins are AMP 1-170291-1
