There are red and green LEDs next to the USB connector on the top of the programmer board. To view the programmer status LEDs remove the ECU case.
Green LED
Red LED
Meaning
On
Off
Normal operation when not connected to KManager.
On
Flashing
KManager communicating with the ECU normally.
On
Flashing/Solid
KManager programming the ECU or datalogging.
Flashing
On
Fault with programmer board - see Updating KPro firmware
Off
Off
If the ignition is on then there is a fault with the programmer board or ECU socketing.
