Vista Virtualization |
Windows Vista & later Windows operating systems do not allow applications to create or change files in the Program Files directory.
Using 'File Virtualization, 'Data Redirection' or 'Virtual Storage' Windows will create a copy of the file in the user's local directory, and make changes to this file rather than the file in the Program Files directory. It will only do this if the application is not run as an administrator.
For instance, when KManager reads/writes C:\Program Files\KManager\KManager.ini the following file is created: C:\Users\<your_account>\AppData\Local\VirtualStore\Program Files\KManager\KManager.ini
This can be confusing as Windows gives no indication that the file has been 'Virtualized'. Saving a calibration into the Program Files directory appears to work but upon viewing the Program Files directory the calibration can not be found.
From V1.3.5 file paths have been changed so that:
During the update process setting and display files will be copied from the Program Files directory to the user local application data directory. Calibrations and datalogs stored in the Program Files directory will not be copied, but it is recommended that these are moved to My Documents manually. |
