Units Settings |
This tab contains settings for the unit display in the tables window.
Lambda Unit - the lambda unit used for display, either lambda (relative to stoichiometric) or air/fuel ratio.
Note that inch vacuum units and most pressure units are usually expressed based on atmospheric pressure rather than using an absolute base. |
