Lotus Dash
With the KPro4 the US Lotus dash may be driven directly.  It will not work on Euro vehicles.
Disable the multiplexer output.
Select digital output.
E14 FTP = fuel level sender
E16 PSP = oil pressure switch
B9 VTP = AC switch
You will need a PRB ECU to support the FTP and VTP inputs.
For the 2008+ dash connect a momentary switch from analog input 7 to +5V.  This button cycles through text displays on the bottom line of the dash LCD.
