CAN Output (Hondata & MoTeC)
Hondata CAN output
Format: 11 bit, 250 kbps, 500 kbps, 1mbps (selectable), big-endian
Speed: 100 Hz, cycling through the packets
The KPro4 does not have a CAN termination resistor.
MoTeC SDL/ADL
500 kbps, otherwise the same as above
CAN Packets
ID
Description
Data
Conversion
0x660
Rpm, speed, gear
Rpm (16 bits)
Speed (16 bits)
Gear (8 bits)
Voltage (8 bits)
rpm
speed (kph)
gear
volt / 10 (volts)
0x661
Temperatures
IAT (16 bits)
ECT (16 bits)
MIL (8 bits)
VTS (8 bits)
CL (8 bits)
air temp (ºC)
coolant temp (ºC)
check engine light
VTEC status
Closed loop status
0x662
Throttle position, manifold pressure
TPS (16 bits)
MAP (16 bits)
tps (%)
pressure / 10 (kPa)
0x663
Injector duration, ignition advance
INJ (16 bits)
IGN (16 bits)
inj / 1000 (ms)
ignition advance (º) signed value
0x664
Lambda
Lambda (16 bits)
32768/ lambda (lambda)
0x665
Knock
Knock count (16 bits)
count
0x666
Cam angle
Target cam angle (16 bits)
Actual cam angle (16 bits)
degrees (º)
degrees (º)
ID
Description
Data
Conversion
0x667
Analog inputs 0-3
Analog0 (16 bits)
Analog1 (16 bits)
Analog2 (16 bits)
Analog3 (16 bits)
voltage (volts) x 819.2
0x668
Analog inputs 4-7
Analog4 (16 bits)
Analog5 (16 bits)
Analog6 (16 bits)
Analog7 (16 bits)
0x669
Ethanol content
Frequency (8 bits)
Ethanol content (8 bits)
Fuel temperature (16 bits)
frequency (Hz)
ethanol content (%)
temp  (ºC)
