af ration via eld
Posted: Mon Aug 31, 2009 9:42 pm
by DOHCAccord
Ok I have my plx m300 wired up and feeding the wideband signal to the eld input. is there a way to actually have it read as air fuel, now it just reads as voltage. id like it to be 13.1/11.1/14.1 etc etc
Posted: Mon Aug 31, 2009 10:00 pm
by allm0t0rGSR
go to parameter, den closed loop, by wideband input source change to D10 ELD....
Posted: Tue Sep 01, 2009 12:10 am
by fly_n
after u have input the voltage conversion info for plx in the closed loop tab,
go to,
options/sensors/AF/units & select A/F ratio.
also make sure your display min & max(just under units selection) are outside what u want to see on the graph.
Posted: Wed Sep 02, 2009 8:56 pm
by DOHCAccord
thanks, appreciate it
Posted: Sat Sep 05, 2009 1:38 pm
by 97turboD
could someone explain the voltage calibration and what numbers you maybe used iam using the PLX wideband as well. thanks
