Lambada Voltage
allm0t0rGSR
Lambada Voltage
Post by allm0t0rGSR »
im having a problem with the reading of the afr because my input from my wideband is showing 4.98v (22.39 afr) but in smanager it show 0.00v (7.35 afr)...everything went wrong after updated to beta 1.4.3...i also tried used D14 but still the same...
Setting frm analog 2 input:b6 removed r2,r3
0v=7.35afr
5v=22.39afr
Setting frm closed loop: wideband lambada
0v=7.35afr
5v=22.39afr
help me pls i am having so much a hardtime tuning my car...
you have not posted the calibration
allm0t0rGSR
sorry.thanks
That datalog looked perfectly fine as far as reading AF ratios. You aren't making any boost.
allm0t0rGSR
Spunkster wrote:That datalog looked perfectly fine as far as reading AF ratios. You aren't making any boost.
yes im not making any boost because im trying to tune for no boost for now....
i noe the afr look alryte but look at the end of the datalog lambada voltage(0.00v) and input wideband (4.98v) are different... aren't they supposed the same value all the time but there not....
