Problem with IAT Sensor
Posted: Sat Aug 29, 2009 12:54 pm
Hello !
I might ask something very obvious here, but I am not able to figure this out myself.
I have a PRB hooked up to a K20A with JSRC and 650 cc injectors.
It seems like there is some kind of problem with the IAT sensor. Could someone please take a look at the linked .kdl file ?
IAT.kdl
The engine started with cams at 0 degrees. The IAT sensor was throwing all kind of data from -5 degrees celsius up to about 28 degrees Celsius which actually was the ambient temperature at that time.
Obviously there is something wrong, the IAT should be somewhere around 25-27 Celsius at all times and not going down & up to or below zero. However a little later everything seemed to be OK again.
I have some other .kdls where the IAT is stuck at 35.2 degrees Celsius and the cams are locked at 0 degrees again. But I also have some datalogs where just everything is fine.
Do you guys believe this is caused by
* a faulty IAT sensor
* wiring problem
* faulty ECU ?
I cant seem to really find this out. Sometimes everything works just ok and sometimes the IAT sends incorrect information.
Has anybody ever experienced something like this ?
Any help is appreciated.
Thanks TC
IAT.kdl
* wiring problem
* faulty ECU ?
Thanks TC
