K-pro on k24a4
Frugal_Rhombus
K-pro on k24a4
Post by Frugal_Rhombus »
So I have an 05 Accord LX 5-speed with the stock k24a4. I plan on doing a k20 head swap and I want to turbo charge it using a hx35 turbo and a Kpro ECU. However, I have been told that the kpro won't fit on an accord. So I figured I'd come to the source and find out for sure. I found someone that says he has made a wiring harness that will allow you to use a kpro on an accord but I'm not too sure about that.
Currently we do not offer the K-Pro for the Accord.
Frugal_Rhombus
Ok, thanks. I looked into it some more and the wiring harness that is supposed to let you put it in an accord is $350. That seems like a lot just for wiring.
