Installation complete but no dice!
Posted: Wed Oct 15, 2003 11:07 am
by BlueSI
I went a couple of weeks ago and got my hondata put in:
S200 Boost and Data logging
550 RC Injectors
Everything was installed and ready to go but when it was fired up the car ran for about 2 minutes and then shut off.
The hondata went into lymp mode and after that it was downhill.
My tuner tried different harnesses, ecu, blue boxes chipped it 2 times and it still would not come out of lymp mode! I had to put back in the Factory ECU and Injectors because the car wouldnt start with the Hondata and Injectors.
Is this a common occurence or can some one shed some light on what it might be! :cry:
Joshua Kriner
Revhard Stage 2C
Posted: Wed Oct 15, 2003 4:44 pm
Were you using saturated or peak and hold injectors and were you using a resistor box?
Posted: Thu Oct 16, 2003 6:43 am
by BlueSI
Saturated with no injector box!
Posted: Thu Oct 16, 2003 6:29 pm
by QUICKSILVER RACING
Just a very wild guess. What basemap are you using. Did you check your mixture. Sounds that the car is running verrry rich... making you think it is in limp mode.
Posted: Fri Oct 17, 2003 5:11 am
by BlueSI
Funny thing is that yesterday I plugged in the ECU and the Hondata, (with stock injectors and stock ECU) tried ot start it a couple of times and it finally started and ran fine , but ran about 2500 RPM. So it is not my ECU or my Blue Box. I have a feeling the shop wired my injectors up in reverse, but not sure as of yet!
But I have been told that the mixture needs to be leaned out before i start it on the ECU so it doesnt choke so I guess we will see!
Thanks :wink:
Posted: Mon Nov 24, 2003 12:34 pm
by BlueSI
Still having issues with my car not staring but I have gain some knowledge! I now know that after installing the injectors and the hondata and letting it run for about 30 seconds it still cuts off , but I did try something new, I held down the gas pedal all the way to the floor and started the car and it ran, but crappy, so I dont know what that means but I guess something is wacko with the basemap!
