Injector Voltage & Deadtimes?
Posted: Thu Jul 30, 2009 3:34 pm
by Manny1987
How would I be able to find out what my injector Voltage and Deadtimes are? I have RC750's Sat. 12.5ohms. Is there an equation or a site other then
http://injector-rehab.com/kbse/lag.htm. Ive heard that there not accurate. I also spoke with John from RC and he said that my injectors are 13.5v @ 1.40. Thats all he had for me. I also noticed in the Maps provided with S300 that theres preset or done maps with bigger injectors placed/punched in but the injector info below is still the stock info? What could be done????
Posted: Thu Jul 30, 2009 4:34 pm
Information off of Injector rehab is what I've used and it has worked for me.
Posted: Thu Jul 30, 2009 4:40 pm
by Manny1987
Thanks for the info. Ill see what I can do. I noticed that theres six columns in the compensation area on S300 they only give 5 references on there page. What would I do for 9 to 8 Volts. this is what I have now for my RC 750 Saturated.
8.96 10.01 10.98 12.04 13.00 13.96 15.02
1.70 1.36 1.12 0.92 0.76 0.63 0.50
Posted: Thu Jul 30, 2009 4:57 pm
More than likely you will never see the extremes of the table
Posted: Thu Jul 30, 2009 5:03 pm
by Manny1987
so what i have now is that what you would say is good would you go with this as a good solution or just an ok just to get by solution. I'd like to get it as close as possible.
Posted: Fri Jul 31, 2009 9:37 am
As long as you enter the information from Injector Rehab it should work properly. When properly tuned you should not see any starange af ratios due to battery voltage.
Posted: Thu Oct 01, 2009 7:54 pm
by ak94gsr
this website does not work anymore.....does anyknow of another site with info like this???
Posted: Fri Oct 02, 2009 7:30 am
I've found that the listed dead times are 0.1 - 0.4 ms lower than the correct values - they could be measured in a different way. 0.1 ms makes a huge difference on a large injector, so spend some time getting the values correct before tuning the main fuel tables.
