Hesitation exiting corners
mchammer
Post by mchammer »
Civic EF race tuned/setup only, road racing
K20A2, stock internals, PRB Intake, CAI, Custom headers, 3in exhaust, magnaflow muffler
Kpro, (no datalogging) , Kmanager 1.3.6.0, PRB ECU, 215 whp dynojet,
410 injectors, adj fuel rail, dual fuel pump, 1 litre reservoir up front to prevent fuel slosh in corners, fuel pressure constant through cornering
Problem: Coming out of corners hard, motor bogs down, wont accelerate for a few seconds, then accelerates perfectly to redline down straightaway.Doesnt matter if I mash or ease into throttle. AF 14.6 to 13.5, MAP 900 to 999 Mpa. Any ideas? Thanks ahead
Mchammer
PrsxKing
Post by PrsxKing »
05 Type-s w/K-PRO
Im having the same problem but it happens whether im driving straight or turning. When I hit 1500 RPM's the car hesitates and then it goes back to normal. This is only when im slowly taking off. If I drive it more agressively then it doesnt happen.
Also I have noticed when I am cruising at any speed past 1500 RPM's, I cant keep it at a steady speed. When I want to give it a little gas it acceletates not letting me just cruise. It is extremely annoying and I have tried many things.
When I learn my TPS it reads -4 idle and 92 full throttle.
No vacuum leaks whatsoever. It idles perfectly.
The car runs perfectly fine besides thoise 2 issues.
Throttle cable is not too tight. Its actually more on the loose side.
