Voltage Fluctuation Problem
Posted: Wed Oct 15, 2003 7:30 am
by turbosi92
I am having a fluctuating voltage problem on my 92 civic si with my Hondata. I have read somewhere that you can remove the ALTC wire on the ECU harness to fix this issue. Is this something you can only do on an OBD2 car? Or should I remove this wire on my OBD1 Civic?
If this is something I should do, which wire is this on the harness? :?:
Posted: Wed Oct 15, 2003 4:46 pm
You can try this and see if it helps.
The wiring diagram can be found at http://www.hondata.com/techwiringgsr.html
Posted: Wed Oct 15, 2003 6:09 pm
by turbosi92
Spunkster wrote:You can try this and see if it helps.
Try what?
Posted: Fri Oct 24, 2003 4:22 pm
by turbosi92
Try what?
Bump
Voltage control
Posted: Mon Oct 27, 2003 8:08 am
This only is a problem on OBDII cars, but if you want you can try removing the ALTC wire from connector which plugs into the ECU to see if it helps.
Re: Voltage control
Posted: Mon Oct 27, 2003 7:16 pm
by turbosi92
Hondata wrote:This only is a problem on OBDII cars, but if you want you can try removing the ALTC wire from connector which plugs into the ECU to see if it helps.
Can't you just disable ELD in ROM Editor? Someone mentioned this on Honda-Tech.
Re: Voltage control
Posted: Mon Nov 10, 2003 5:44 pm
by turbosi92
Hondata, can you verify with me about Disabling the ELD?
Disable ELD error
Posted: Tue Nov 11, 2003 8:46 am
Disabling the ELD error does just that - disables the error code if you don't have an ELD. Try removing the ALTC wire from the harness.
Re: Disable ELD error
Posted: Tue Nov 11, 2003 3:14 pm
by turbosi92
Hondata wrote:Disabling the ELD error does just that - disables the error code if you don't have an ELD. Try removing the ALTC wire from the harness.
What is ELD?
Any idea what PIN it is for the ALTC wire?
Posted: Wed Nov 12, 2003 6:50 am
by DaX
ELD = Electric Load Detector
Posted: Thu Nov 13, 2003 7:15 am
by turbosi92
DaX wrote:ELD = Electric Load Detector
Thanks Dax
So which pin is the "ALTC" wire?
