How to change ELD volt reading into AFR
da_dude
Post by da_dude »
I just install my AEM uego into my s300. Wire the white wire from the wideband into ELD pin. Disable ELD it in misc. Romover R136 and R138 from the ecu. Now, my ELD display is reading it volt. How do I covert it so that it'll read air fuel ratio over volt. Thanks.
http://www.hondata.com/techplxwiring.html
Make sure you have the closed loop tab setup properly and then make sure you are looking at the AF reading in datalogging.
da_dude
Post by da_dude »
I think I got it. Thanks.
