Help!! i have s200 problems
Posted: Mon Oct 13, 2003 11:30 pm
by chrisnhawaii19
i have a b20 with jrsc with 8psi of boost.. 550 injectors, obd0 to obd1 conversion harness from locash racing.. also i have the s200 hondata ecu with boost... i have double and triple checked the wiring for the car.. but the engine check light keeps blinking 4 times and the engine runs alright but not the beast at idle but when you press the gas the car bogs and engine check light comes on for the crank angle sensor.. im using the obd1 distributor... i would like the distributor diagram so i can see if the distributor is wired correctly.. according to the diagram from locash its right.... i need the color codes and the wires i have to connect from the obd0 wiring to the obd1 wiring.. im also using the ls ECU obd1... and wired in a 4 wire o2 sensor....please help...oh yea the car is a 88 crx dx with a converted harness to SI.. also tried to change distributors with no cure.. please help me
