Water methanol for my 05
Posted: Wed Jul 22, 2009 10:33 am
Hi Hondata I came across this in DIY water methanol at clubrsx.com . I have a 05 rsx type s JR supercharger with Kpro. I don’t understand what is written below.
ATTENTION 05-06 OWNERS. DO NOT USE CONNECTOR GOING INTO YOUR WIRE HARNESS. You need to pull out the connector with is plugged into ECU, only then you will get the mapping right.
How do you pull out a connector from the ecu without damaging the ecu? What connector is this? I want to use E21&E22 connectors for arming the water methanol through k pro. Could you elaborate more on this please?
Thanks Kam
Thanks Kam
