Switching Point
senjam1
Switching Point
Post by senjam1 »
Whe does the map switch from low to high?
whenever you set it to?
megomaniac
Post by megomaniac »
the switching point is when you go from the low cam to the high cam. (vtec)
H22A4
turbo
S300
allm0t0rGSR
vtec window
Post by allm0t0rGSR »
when is the vtec switch on is it on the lower boundary setting or on the upper boundery setting?im kind a counfuse when i look at my data log it switch to high speed table when it reach to lower boundary? is this normal and is it mean that the vtec is already on?
what is lower boundary for?
what is upper boundary for?
thanks
allm0t0rGSR
lower boundary=low to hi speed table
upper boundary=hi to low speed table
i dont know i still dont understand?
can u pls tell me how u understand what is lower and upper boundary?and how it work plssss...
fly_n
Post by fly_n »
cruising/light throttle/low engine load = cams switch at upper boundary
racing/WOT/high load = cams switch at lower boundary
driving somewhere in between low & high engine load = cams switch at interpolated value between upper & lower boundary.
what the ecu determines as low or high engine load according to upper & lower boundaries is set by the figures u enter to the right of the rpm values.
allm0t0rGSR
thanks alot...
what if you put the same rpm for both lower and upper boundary let say at 5000rpm is it still the vtec will pop up at 5000 rpm?
fly_n
Post by fly_n »
yes,if u read the particular settings tab in question,it says thats how u disable the boundary window,by setting both upper & lower at same rpm value,then it will always switch at that one value regardless of engine load.
