Fuel: IAT Compensation
silverspoon1996
Post by silverspoon1996 »
Is there any IAT compensation for fuel on flashpro??
The ECU has IAT compensation. Currently you can not edit it.
silverspoon1996
Doug,
Do you know off hand what the incriments are... when I was dyno tuned My IAT were around 83-87 during normal driving its around 103-108, and it is not compensating enough...
I am using the RDX start up map, and its dynopack tuned.
If you want a reply from Doug you will need to email him.
There are about 30 IAT compensation tables, for different loads, open loop, closed loop, sensor errors. It is not possible to say what the actual compensations will be just from looking at the tables.
silverspoon1996
ok, do you guys think IAT compensation control will ever make it into flashpro manager?
Possibly.
silverspoon1996
Just to let you guys know.. I saw a 20 HP difference due to IAT from last week to this week... we tested IAT ranging from 85 degrees up to 122 degrees. and A/Fs were changing alot. Going to eventually need this or get retuned when it gets colder out.
Normally the stock IAT adjustment tables work fairly well, and if they need to be changed it is a sympton of some other problem.
