Hondata Reflash FN2
Akula
Hondata Reflash FN2
Post by Akula »
Hello Hondata,
One question, why the reflash fn2 is so rich under 3800rpm ? (under the vtec)
Thanks in advance, best regards!
Akula
Do you have a dyno graph? If it is running rich under 3800 rpm then it could be the AFM signal is getting altered by the intake configuration.
Akula
Post by Akula »
thanks for the reply,
my fn2 is stock, i have a normal BMC panel filter only, (like K&N)
here a dyno graph:
here another one, reflash on my fn2 vs another fn2 stock
Best regards!
CTR FK2 R-03220
The ECU will run closed loop for some time under full load conditions - normally until 3800 rpm, but sometimes there is a time factor as well.
Akula
Post by Akula »
thanks for the fast reply!
you mean that with passing of the time under the 3800 the ecu will change and become less rich or run more better ?
Best Regards!
CTR FK2 R-03220
The time frame is in the order of 0-10 seconds. The ECU runs closed loop for a while after you give it full throttle, then switches to open loop. It also seems to switch at 3800 rpm to open loop.
Akula
Post by Akula »
ermm, sorry Hondata but .. :)
what do you mean with "closed loop" and "open loop"
thanks!
CTR FK2 R-03220
