car jerks at partial throttle after s300 install.......
Posted: Tue Jul 14, 2009 3:53 pm
by dcteg1.6na
i just installed hondata s300 in my integra and now whenenver i am at partial throttle the car jerks like crazy but goes away when at wot i saw another post on here a while back and it said to change the map sensor in the idle tab from 10 to 15 tried this and still it does same. anyone know what else it could be?
mods:
b16a2 (pr3) stock block w/ internals
b18c1 (p72) head
s2 pro2 cams
s2 im
type r valvetrain
rc 310cc injectors (current)
440cc injectors (also tried)
short ram intake
4-2-1 headers
stock gsr cat-back
i will upload my calibrations in a bit
Posted: Wed Jul 15, 2009 3:07 pm
by dcteg1.6na
nobody can help this is my DD so any help will be greatly appreciated....
Posted: Wed Jul 15, 2009 4:04 pm
Has the car been tuned?
Posted: Wed Jul 15, 2009 7:06 pm
by dcteg1.6na
yes they are the ones that set the s300 for me but didnt give me a hp or tq readings i will be getting it retuned at a different tuner but wont be able to for a few weeks thats why im trying to fix the problem
Posted: Thu Jul 16, 2009 3:44 pm
Do you have a wideband?
Posted: Thu Jul 16, 2009 4:08 pm
by dcteg1.6na
no not yet but will be getting one the s300 is what showed the 16.x a/f
Posted: Thu Jul 16, 2009 4:37 pm
Without a wideband you cannot get an AF reading to tune by. You will need to take this to a tuner in order to fine tune any problems you are having.
Posted: Thu Jul 16, 2009 6:03 pm
by dcteg1.6na
ok but wut wld cause the jerking
Posted: Fri Jul 17, 2009 9:56 am
You describe a part throttle issue, but your datalog is of the car not moving. To avoid damaging your engine since you do not have a wideband I strongly recommend taking the car to a tuner even if it just for a base map to run safely until your dyno appointment.
Posted: Tue Sep 15, 2009 5:45 pm
by Japhatch
i had the same kind of problem..i had to change the throttle value into the negative like.. -2.75% to 100%.
Posted: Mon Sep 28, 2009 10:28 pm
by fg2ghost
i would say try this switch the tps and map sensor plugs. try that and run it again just to double check. cause it looks like most of the revs u made the tps is mostly at 0 %. and hops every once in a while. just my 2 cents. it wont hurt to try man. good luck
jerky at pt thro
Posted: Thu Nov 05, 2009 12:40 am
by hontoy
i had the same issue, crusin barley on the throttle i had a leaning out issue which causes jerkyness. i changed the injector lag time in the fuel trim parameter(or injector voltage compensation). set the specs for my injectors and it worked alot better. go to "injector-rehab.com" for the specs. it will also change your af ratios, so a wide band is highly recommended before you go to far.
Posted: Sat Nov 07, 2009 1:26 pm
by OSracer
Ive experienced this before with fouled spark plugs and one other time with a bad wire. Tuneup?
