car jerks at partial throttle after s300 install.......
dcteg1.6na
Post by dcteg1.6na »
i just installed hondata s300 in my integra and now whenenver i am at partial throttle the car jerks like crazy but goes away when at wot i saw another post on here a while back and it said to change the map sensor in the idle tab from 10 to 15 tried this and still it does same. anyone know what else it could be?
mods:
b16a2 (pr3) stock block w/ internals
b18c1 (p72) head
s2 pro2 cams
s2 im
type r valvetrain
rc 310cc injectors (current)
440cc injectors (also tried)
short ram intake
4-2-1 headers
stock gsr cat-back
i will upload my calibrations in a bit
"If you aint breakin shit, you aint goin fast enough!!"
'95 DC SE w/'00 conversion 5spd B16A2 block B18c1 built head hp?? tq?? Hondata s300 - DD
dcteg1.6na
nobody can help this is my DD so any help will be greatly appreciated....
Has the car been tuned?
dcteg1.6na
yes they are the ones that set the s300 for me but didnt give me a hp or tq readings i will be getting it retuned at a different tuner but wont be able to for a few weeks thats why im trying to fix the problem
Do you have a wideband?
dcteg1.6na
no not yet but will be getting one the s300 is what showed the 16.x a/f
Without a wideband you cannot get an AF reading to tune by. You will need to take this to a tuner in order to fine tune any problems you are having.
dcteg1.6na
ok but wut wld cause the jerking
You describe a part throttle issue, but your datalog is of the car not moving. To avoid damaging your engine since you do not have a wideband I strongly recommend taking the car to a tuner even if it just for a base map to run safely until your dyno appointment.
Japhatch
Post by Japhatch »
i had the same kind of problem..i had to change the throttle value into the negative like.. -2.75% to 100%.
fg2ghost
Post by fg2ghost »
i would say try this switch the tps and map sensor plugs. try that and run it again just to double check. cause it looks like most of the revs u made the tps is mostly at 0 %. and hops every once in a while. just my 2 cents. it wont hurt to try man. good luck
hontoy
jerky at pt thro
Post by hontoy »
i had the same issue, crusin barley on the throttle i had a leaning out issue which causes jerkyness. i changed the injector lag time in the fuel trim parameter(or injector voltage compensation). set the specs for my injectors and it worked alot better. go to "injector-rehab.com" for the specs. it will also change your af ratios, so a wide band is highly recommended before you go to far.
OSracer
Post by OSracer »
Ive experienced this before with fouled spark plugs and one other time with a bad wire. Tuneup?
