Calibration upgrades with new software versions
Posted: Mon Jul 13, 2009 6:26 pm
by gnews
I noticed in the 1.1.0.5 revision that some changes were made to the base calibrations disabling the long term fuel trim. I believe it was mentioned to load the new base calibration to get the benefits. So if I already had my vehicle tuned starting with the Injen CAI, RH MAP calibration how can I import these benefits without losing the benefits of all the hard work my tuner did on the dyno? I looked around and checked for an option to the enable but didn't see anything. I would imagine an "internal" calibration upgrade would be able to be imported but I can't quite figure it out.
Am I SOL or do I need to copy everything my tuner did to a new calibration that has been updated? Is there an easier way?
Re: Calibration upgrades with new software versions
Posted: Tue Jul 14, 2009 12:10 am
by august77
gnews wrote:I noticed in the 1.1.0.5 revision that some changes were made to the base calibrations disabling the long term fuel trim. I believe it was mentioned to load the new base calibration to get the benefits. So if I already had my vehicle tuned starting with the Injen CAI, RH MAP calibration how can I import these benefits without losing the benefits of all the hard work my tuner did on the dyno? I looked around and checked for an option to the enable but didn't see anything. I would imagine an "internal" calibration upgrade would be able to be imported but I can't quite figure it out.
Just connect your FlashPro to your laptop... download the current map in your car and open it. Once u have done that, just re-upload to Flashpro then to ECU. Any changes or updates will be instantly made to the map.
That is from my understanding of how the FlashPro and software work..
Posted: Tue Jul 14, 2009 7:36 am
That is correct. If you're using a unmodified base calibration then you're better off selecting the same calibration again and uploading that.
Posted: Thu Jul 16, 2009 3:30 pm
by aka_si
Would you need to re-tune the calibratin due to the new rev?
Posted: Thu Jul 16, 2009 3:46 pm
No you should not
Posted: Thu Jul 16, 2009 5:27 pm
by gnews
Thanks!
