boost by gear PWM problem
billy_bad_a$$
Post by billy_bad_a$$ »
Boost by gear is only working in 1st and half of 2nd then nothing. I have attached the datalog showing PWM works like its suppose to then half way thru 2nd it goes to 1%. This happened on both of my passes and I cant figure it out. please help as I have a race the day after tomorrow and need this fixed.
billy_bad_a$$
I guess nobody can help. Dont know if it matters but I have a hondata solenoid.
locash
Post by locash »
Can you post the calibration? This might help..
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
locash
Post by locash »
On a side note, you are maxing out the PWM duty cycle as well, which is probably your problem.. What gate springs are you running, what turbo, etc?
Locash Racing, LLC
billy_bad_a$$
locash wrote:Can you post the calibration? This might help..
how do I post the calibration?
billy_bad_a$$
locash wrote:On a side note, you are maxing out the PWM duty cycle as well, which is probably your problem.. What gate springs are you running, what turbo, etc?
cant remember what springs are in there but we are changing them this week and im running a gt4088. we had it so the pwm should only run 99% at the most but I guess thats cutting it too close and its spiking?
billy_bad_a$$
Ok I guess nobody knows what the problem is. Thanks anyway
You haven't posted the calibration you are using.
billy_bad_a$$
I don't know how to. I am not the tuner just the owner. I asked how to do it so I could.
Post it the same way you posted the calibration. If you don't have the calibration contact your tuner and have them email it to you.
billy_bad_a$$
my tune
Look at your air temp compensation table while looking at the datalog and you will see that you are adding 2% duty cycle to the 99% you already have set whihc bsically makes it go back to 1% (99 = 2 = 101%) and excedeing 100% cannot occur. Either remove the compensation correction or you may need to increase the wastegate spring pressure.
billy_bad_a$$
Good call. Thanks a lot for your help
