50 degree cam angles safely on JDM Civic Type R
FlashPro questions & answers specific to the FD2 Japanese Civic Type R
dellas
Post by dellas »
Can I run 50 degree cam angles safely on FD2 JDM Civic Type R(no piston to valve contact)?
If not what is the maximum safe cam angle?
The VTC mechanical stop, rather than the ECU, limits the maximum cam angle and prevents valve/piston contact. In a stock vehicle the VTC will run to 50 degrees for VTC cleaning.
dellas
VTC Cleaning
Post by dellas »
Hondata wrote:The VTC mechanical stop, rather than the ECU, limits the maximum cam angle and prevents valve/piston contact. In a stock vehicle the VTC will run to 50 degrees for VTC cleaning.
Thanks, that clears that up for me....
What do you mean by "VTC cleaning"?
The ECU 'cleans' the VTC solenoid by going to full advance a few times per drving cycle.
rensoyka
Post by rensoyka »
man, the stuff I learn on this site is farking amazing.
