S2000 Gear Ratio Calcs
0piston
Post by 0piston »
Hi which is the accurate setting? when I load new calibration for the 2000-2003 s2000-ap1.kal the gear comp looks like this:
3.266 2.130 1.517 1.212 0.972 0.780 4.764
when I click "select ratios" button for s2000 00-03 it is different:
3.133 2.045 1.481 1.161 0.979 0.810 4.756
And when I tried to confirm researching the web for the drivetrain ratios they were different once again, which are the right settings?
thanks
0piston
Post by 0piston »
can anyone confirm?
Garrett_si
Post by Garrett_si »
AP1 6-speed, close-ratio Primary Gear Reduction - 1.160 1st gear - 3.133 2nd gear - 2.045 3rd gear - 1.481 4th gear - 1.161 5th gear - 0.970 6th gear - 0.810 Reverse - 2.800 Final Drive - 4.10 with Torque-Sensing Limited-Slip
AP2 6-Speed Transmissions Gear Ratios: Primary Gear Reduction - 1.208 1st gear - 3.133 2nd gear - 2.045 3rd gear - 1.481 4th gear - 1.161 5th gear - 0.942 6th gear - 0.763 Reverse - 2.800 Final Drive Ratio - 4.100
DC5RK20A
Post by DC5RK20A »
Those gear ratios look like the 5R Teggy if I am remembering correctly.
The Power of Dreams...
2007 Snisen
