Closed loop causes a/f to lean out
Posted: Wed Jul 01, 2009 9:10 pm
I would like to run my turbo gsr in closed loop mode using the stock o2 sensor to clean up any parts of the tune that are slightly off. After my tune, I put the stock o2 back in and enabled it using s300. After I did this, the car would randomly lean out to the point where my PLX wideband would read "lean", and the car would loose power and bog. At first I figured that my stock o2 sensor was probably fouled, but I just replaced it with a brand new Denso sensor and still have the same problem. Any help/ideas would be greatly apreciated. Thanks!
