Injector Size
Quade
Injector Size
Post by Quade »
When changing the injector size under Fuel Trim, shouldn't the fuel values in the Tables change accordingly? It don't change for me.
Fuel trim has nothign to do with the tables. You start with a stock base map, then adjust the injector size, then make adjustments to the fuel trims until you get it running about where it needs to be, then start making changes to the table to fine tune the AF ratio.
