B16a1 with cams wont idle
robmobster
Hi Everyone im new to hondata and would like to learn a few things so my car can be driveable i have a crx with a b16a1 block and b18c1 head on obd1 440cc injectors skunk 2 pro 2 cams skunk 2 pro valvetrain 3 angle valve job skunk 2 intake manifold dc 4-2-1 header bottem end is stock. i recently installed the hondata s300 and loaded the ITR base map the car will only start when i press the gas and wont idle at all just drops down and stalls. also noticed the car runs a litle lean how would i adjust the AF ratio. All input would be greatly appreciated or a callibration would be great. thank you. also i included the callibration im using i dont know if this helps
robmobster
robmobster
try this. i have pro1 cams in my b16.this map is untuned.your ingnition map are wrong on idle area.you must idle on colum 4-5,5-6 with this cams,you must put in 16,5º of advance in your idle area.
check your tps calibration,and try the idle adjustment whith hondata help manual.
pro cams likes extract 10-20% of fuel in idle area,see the skunk2 catalog in page 17.
sorry for my english,i am spanish user
robmobster
OK I loaded that map (mapa inicial) i put 16.5 advance in the idle area increased the fuel table on columns 4-5 5-6 the car was idling but running lean i have a datalaog and the callibration people please help me i have to get the car at least to be driveable were i dont need to worry about it leaning out
