S2000 AP2 Non DBW Turbo Basemap needed to get to my tuner
edomund
Post by edomund »
Hey guys,
I have a 2005 S2000 non drive by wire throttle with the Greddy Turbo Kit.
I'm using the 550 RC injectors that it comes with.
I just need a basemap thats safe to drive straight to my tuner & dyno.
Thanks,
Ed
AP2 S2000 Turbo
cranny
Post by cranny »
well f your running Kpro i assume you have an 02-04 rsx wideband O2 installed. just run the 650cc injector S2000 map in Kmanager , set in fuel trim the injector size to 550 , and baby it there. these ecus run wideband closed loop so.
edomund
Post by edomund »
Yeah I wish I could, but the s2000 Kpro doesn't run with the rsx wideband it uses the stock s2000 narrowband under closed loop.
I guess I'm going to have to take my Greddy Emanage Ultimate turbo basemap & try to apply the ignition & fuel map adjustments to the stock Kpro maps. The EMU maps are just piggyback maps so they +/- degrees of timing & % of fuel to the stock tables. I think if I apply the same adjustments to the Kpro map it will be close enough to drive to my tuner if i stay out of boost as much as possible.
What do you guys think?
AP2 S2000 Turbo
