need help installing hondata boost solenoid on 04 rsx-s
Posted: Sat May 23, 2009 12:55 pm
by afnewkirk13
im not sure from where i need to hook up my boost solenoid lines. i know this isnt exactly where to post questions about this item but i didnt see anywhere else so im sorry. i know where to tap into the 12v source and into myy ecu but as far as the vaccuum lines im lost. any help is really appreciated and thanks for any help in advance
Posted: Sat May 23, 2009 1:49 pm
by pb16b
ignore the wiring, that's for s300. vacuum should be the same.
Posted: Sat May 23, 2009 6:34 pm
by afnewkirk13
does it matter which side you hook the lines up to on the solenoid? thanks
Posted: Thu May 28, 2009 2:47 pm
If this is a Hondata boost control solenoid you will need to follow the instruction that came with the solenoid. If this is a GM solenoid then you need to follow the diagram posted above. If this is not a Hondata solenoid you will need to contact who ever you purchased it from.
