my jrsc civic o2 sensor high voltage
karl.hart
Post by karl.hart »
my car keeps putting the engine light on. and dont go into closed loop any advise i have changed the o2 sensor and it made no difference its a uk kpro on a uk car with a jackson racing supercharger and 650cc injectors with dc mani and all the usual bits and bobs mapped at tdi north. i get a bad judder on the motorway aswell around 3000rpm and 3500rpm on part throttle. i will upload a datalog. the light comes on and after a min of deleting it, it runs not to bad but if i turn off the engine and restart the light comes on again and runs rough till i delete it. as soon as i keep my laptop with me and delete it when am driving its fine till the next start up
how do i upload my datalog
karl.hart
Post by karl.hart »
think i will leave it mate i dont know the serial no and i cant access my calibration as my map is locked by the tuner i heard yuo guys would be able to help but i cant see what difference my serial no makes ect all you need is a datalog and details of mods
Your serial number can be found in KManager by using the 'Online -> Information' window.
The datalog would tell us the error code - the first step is solving the problem. It would also show us the closed loop operation which may have some bearing on your problem.
karl.hart
Post by karl.hart »
thank you
my serial is 02498
software is 1.3.5.4
code is p0132 o2 sensor voltage high
on the live data i can see its not going into closed loop even on tick over.
then the light comes on so i delete it without turning off the engine and it runs fine and closedloop starts working sometimes. but then i turn the engine off and restart it does it again really annoying is their any sensors that could be telling it that its a cold engine and not to run closed loop.
2001 civic type r ep3 (k20a2)
underbonnet major mods listed only.
Jackson racing supercharger 8psi 650cc rc injectors
Hondata thermal heat shield
Hondata K-pro
Hondata throttle body modification
Spoon baffled sump
Magnetic sump plug
HKS iridium spark plugs
Samco hose kit
AEM CAI with hydroshield
AEM fuel rail
DC 4 2 1
blue flame back box and desilenced b pipe.
Front and back ES Engine mount
Polyflex Gearbox mounting
Alloy Gearbox bush inserts
Engine torque damper
DC5 Gearbox for longer 4th 5th 6th ratios has a longer final drive with a lsd from one of TGM's race cars.
Facelift flywheel
Stage 3 Gripforce Clutch kit.
earth kit
mugen oil cap and rad cap
karl.hart
Post by karl.hart »
does that not help
karl.hart
Post by karl.hart »
so what else do you want to know mate sorry but i am not that good with forums
karl.hart
Post by karl.hart »
i guess you cant help o well back to tdi north next week they will sort it
We can't help you if you don't help us.
