I've read on the S300 section you can toggle between maps by going Parameters > Secondary tables tab
Any suggestions on preforming this with my Kpro/kmanager?
I want to be able to switch between maps on the fly, one for pump gas and one for race fuel
or thinking
a switch between low boost/pump gas and for high boost/race gas
thanks for any ideas on setting this up
Ideas on setting up a map switching for pump/race gas
If Hi/Low switch activated boost boost control was enabled, and there was also Nitrous switch setup to add or subtract fuel/ignition...
which one would trigger first, if all conditions are made equal?Could I get them to work together thinking about using these this combination to try to achieve what I am doing...
