IACV troubles
Posted: Sat Apr 25, 2009 12:29 pm
its a built gsr sleeved to 84mm
10:1 cp slugs
ls manley rods
ls scat crank
port and polished head with .5 over rev valves
precision 780 with fjo driver
neukin ram horn mani and 3 inch down pipe
precision sc61
3 inch exhaust
aebs intake mani and 68 mm throttle body
msd set up
ngk race plugs
60 psi fuel
gm 3bar map
so I have tried to set the idle air speed and when I unplug the iac car dies. Well I changed it out to another iac that was "supposed" to be working properly. OK its changed out try again same thing, car just dies. Im not running coolant to the iac like most people dont, but I dont feel that matters at all. Do u think I just got another bad iacv or could there be another issue at hand?
10:1 cp slugs
ls manley rods
ls scat crank
precision sc61
3 inch exhaust
msd set up
ngk race plugs
60 psi fuel
gm 3bar map
