no air pressure sensor in P28
DevineCRX
Post by DevineCRX »
I am about to chip a euro p28 (p28-G51) for hondata. When i opened it up, it does not have a air pressure sensor. Will this cause any problems?
DaX
Post by DaX »
Does it appear to have been removed or that it was never there?
DevineCRX
Post by DevineCRX »
it was never there
shinociv
Post by shinociv »
JDM ecu's don't have it either
when you make a chip for your ecu you just need to disable the barometric presure sensor.
If you have ROM editor to program chips it's under the Options tab.
Or tell whoever makes the chip for you to disable it.
even with out it in the ecu and it not disabled the car should run fine
it may give you a error code though.
DevineCRX
Post by DevineCRX »
thanks..thats exactly what i needed to know...
You will also need to disable the injector error.
QUICKSILVER RACING
Post by QUICKSILVER RACING »
I was able to tune a p28-G00 succesfully. I used an S200 and P30G stock basemap.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
5thgencivic
Post by 5thgencivic »
I have a P28-G02 and it doesn't have that sensor either. Do all USDM p28's come with the sensor?
**EDIT** I found out the G in the number means it's not USDM. I wonder what basemap I can use.
