wideband analog input.
bubble_brain
Post by bubble_brain »
new to tuning and i just had a quick question.
when tuning, does the wideband have to be "connected" as an analog input or can i just tune using the O2 as an independent wideband.
crucian
Re: wideband analog input.
Post by crucian »
It can be independent. You can either have the wideband controller simulate a narrow band signal to your ECU or just keep your stock O2 sensor hooked up if you got 2 O2 bungs in your car.
bubble_brain
so during tuning, just go off of what the wideband displays? for datalogging i WOULD need to have it as an input to the ECU correct?
crucian
Post by crucian »
Ok, if you want to have your wideband readout in hondata use one of the inputs available in the "closed loop" tab under parameters. Go here:
http://www.hondata.com/techplxwiring.html
bubble_brain
ah, thanks guys. as far as the adaptor piece goes, i wouldn't need it unless i didn't want code 41 correct?
