FAN controller 1.4.1
Posted: Wed Apr 15, 2009 3:43 pm
by Merfi
the fan controller in version 1.4.1 not working. I set 87'C and fan is turn on about 95'C and turn off about 91.
any ideas?
Posted: Wed Apr 15, 2009 3:58 pm
Your car may not have wiring from the ECU to the fan relay. If it does not, you must wire this yourself.
Posted: Sat Apr 18, 2009 6:12 am
by rudebwoy
so let me get this correct, this feature illiminate the option of buying these overpriced lowered temperature, mugen/spoon etc. fan switches? if so sweet!
Posted: Sun Apr 19, 2009 5:23 pm
by Merfi
can you give me instruction for wiring connection.? Thank's
Posted: Mon Apr 20, 2009 10:18 am
We have always said it is a bad idea to use a colder thermostat and fan switch as it is VERY important that the car is at the proper operating temperature.
There is no wring diagram. If your car does not have the wiring then you must run a wire from the ecu output to the fan relay.
Posted: Tue Apr 21, 2009 1:43 am
by Merfi
I should re-pin existing wire to fan relay?
Where is fan relay physically?
Posted: Tue Apr 21, 2009 9:45 am
You will have to look at a Helms manual for this. www.helminc.com
Helm makes the factory service manual.
Posted: Tue Apr 21, 2009 4:17 pm
by Merfi
What number of pin steering fan relay?
Posted: Tue Apr 21, 2009 5:01 pm
Posted: Wed Apr 22, 2009 5:15 am
by Merfi
A12 is connected directly to fan-switch and second wire switch - to ground.
when I set 87'C then nothing happen.
