not turning over... possible firmware problem??
Andre
Post by Andre »
i just bought a 89 civic with a stock k20a2 which was swapped in 2006.
i dont think anybody messed with kpro since then and i do not have the ecu calibration. although the following line kept popping up..
"The calibration in the ECU (1.2.x.x.) is from an older version of K-manager. Please upgrade the ECU calibration before datalogging from this ECU. "
so i decided to just upload a stock map so i could setup the launch control.
well now the engine doesnt even turn over (i disabled multiplexer and the immobilizer). it started fine 5min before i uploaded the map and as soon as it was uploaded i turn the key to start it and nothing happens. is this something to do with the hardware/firmware being such an old version and it is clashing with the newer calibration? or is it just a fluke and something is wrong with my starting/ignition circuit? (brand new battery and starter)
here is the ECU info:
Hardware 1.00
Serial 01373
Firmware Revision 1.00
Firmware ok? Yes
Software version 1.3.4.0
edit: i forgot to mention that "update firmware" is grayed out/ unclickable.
any help would be much appreciated!
fonz600
Post by fonz600 »
Try clearing the security and then upload the map again.
Andre
Post by Andre »
fonz600 wrote:Try clearing the security and then upload the map again.
i've actually already tried that, still nothing. thanks for the reply though :)
i don't see how the ecu has anything to do with it cranking over or not.
but it just seems like too much of a coincidence for the ecu not to be the issue somehow.
The ECU is not related to the starter circuit. If the engine does not turn over, it is the vehicle wiring.
