Page 1 of 2
NEED HELP
Posted: Mon Apr 06, 2009 9:58 am
by h22acivichatch
I can't figure this out. Running a H22A in a Civic hatch. Running Headers no cat. Short Ram intake. No other modifications. VTEC disabled. running base h22 map.
Car is dumping fuel in to the motor. I have changed the O2 sensor. Hadn't had a chance to change spark plugs to check those.
Re: NEED HELP
Posted: Mon Apr 06, 2009 10:53 am
by crucian
From what im seeing is that your O2 sensor is not reading right. You are running in closed loop and your 02 sits at 3.83 volts the whole time. Check your o2 circuit.
Posted: Mon Apr 06, 2009 11:37 am
What sized injectors are you using?
Posted: Mon Apr 06, 2009 12:26 pm
by h22acivichatch
Stock for the motor.
Posted: Mon Apr 06, 2009 12:28 pm
by h22acivichatch
car runs like crap for 30 minutes. then everything runs like it is suppose to. feels like it is running on 3 cylinders and running really rich
Posted: Mon Apr 06, 2009 12:32 pm
The calibration you posted was tuned on larger injectors (450cc). That would explain some of the problems. Be very careful until you get this tuned properly as if it is running too risch you will wash down the bores and damage the rings.
Posted: Mon Apr 06, 2009 12:34 pm
by h22acivichatch
This was the stock file i pulled on the sManager
Posted: Mon Apr 06, 2009 1:16 pm
by h22acivichatch
Thanks for the input. I'll check it all when i get home. Also will adjust base map to take into account for the smaller injectors. Car ran fine until i switched out the O2 sensor that went bad?
Posted: Mon Apr 06, 2009 10:51 pm
by crucian
Well if your basemap has 450cc selected, then someone saved a tune incorrectly to the stock basemap.
Posted: Tue Apr 07, 2009 8:30 am
by h22acivichatch
changed to 310 injectors no change on how the car ran. Adjusted fuel trip using calc function. o2 sensor still showing 3.85 volts. How do i change the map to compensate for smaller injectors or where do i find the right base map for a h22a with 310 injectors?
Posted: Tue Apr 07, 2009 10:26 am
That is the only map we have for an H22. and it was tuned with larger than stock injectors. You will have to make changes to the fuel trim tab until you get the AF right.
Posted: Sun Apr 12, 2009 9:02 am
by h22acivichatch
so may have found a problem. If i unplug my O2 sensor it should read 0 volts right not 3.85?
Posted: Mon Apr 13, 2009 8:02 am
The ECU pulls the o2 input to 3.85V, so that would be normal.
Posted: Mon Apr 13, 2009 8:43 am
by h22acivichatch
but when i plug my 02 sensor in it doesn't change.? my wires arn't broke. but how would i know which o2 sensor plug is sensor A or which one would be sensor b for the after cat.?? if someone could post a wireing color for o2 sensor i would appreciate it.
Posted: Mon Apr 13, 2009 10:25 am
You cannot tune using a stock narrow band O2 sensor. They are not accurate enough to tune by. They are used ONLY for closed loop operation. You must get a wideband such as the PLX in order properly read the air fuel ratio.
