vtec does not work
b16_sol
vtec does not work
Post by b16_sol »
I have tried everything I can think of to figure out why it's not working.
set it up to not look for the pressure switch, didn't work.
Checked to make sure the solenoid works.
Checked resistance for the wire coming from the ecu to the soleniod.
Both checked good.
Installed a light on the vtec wire, it did not come on when vtec should have engaged... Could there be something wrong with the hondata chip?
What else should I check? if it is the chip, what do I need to do to get it replaced? It's only 6-8 months old and was installed by a shop.
k_boi
Post by k_boi »
is this a LS/vtec or b20vtec setup? I've heard of cases where you have to pin the vtec wires into the ecu wiring.. I dont really know.. But I'll keep you posted. Good Luck bro..
Brian
Elevated Speed
Kauai, Hawaii 96752
k_boi
Post by k_boi »
Ooh.. I think you have to have the press. switch hooked up to make it work.. Because if the ecu isn't getting a feed back of PRESSURE then the vtec will not pop.
Brian
Elevated Speed
Kauai, Hawaii 96752
b16_sol
Post by b16_sol »
it's a b16b. and the s300 has a setting to turn off the pressure switch. The pressure switch is there and works. And no wiring was changed. it's all stock wiring.
The problem appears to be no signal from the ecu to the solenoid.
h22acivichatch
Post by h22acivichatch »
Most likely the transistor inside the honda computer is fried. It has shorted to ground so that everytime the hondata says to turn it on it grounds out so no vtec. Removing the cover off your ECU it will be burn or checking it with a multimeter on connuity with black on a ECU ground and touch the metal tab of the transister that is associated with the vtec if it is shorted it will be shorted to ground. if not check the transister by settinga multimeter to diode setting. if the transistor reads in both direction from left leg to right leg. (switching red on left leg and black on right leg, and swapping them) The transistor is most likely shorted.
http://www.hondata.com/forum/viewtopic.php?t=3772
Have you tried this ecu and s300 in a known good working vehicle?
b16_sol
Post by b16_sol »
I have not tried the ecu in another vehicle.
I have a 94 del sol si, with a b16b swap, jackson racing supercharger, rc 550cc injectors, msd digital 6 ignition, blaster ss coil, hondata s300 in a p28 ecu.
you must post a datalog showing the problem
b16_sol
Post by b16_sol »
Spunkster wrote:you must post a datalog showing the problem
I don't have one yet, but will soon.
Ivan
Post by Ivan »
Check your datalogs to see if the computer is even giving a signal to turn on vtec, and go from there.
