newby
lifebeginsat8000rpm
newby
Post by lifebeginsat8000rpm »
hello
i just got my hondata s300 installed end i am looking foor an map for my d16z9 with skunk intake manifold b16b trothelbody exhaust feulpresser at 3.5bar en i want a good map for it i am new to hondata en dont want to f*ck up the car thats why y look for a goot map before i go start making changens on a basemap ent the basmap gifes 2 errror codes sorry fore my englis i am from belguim:d ... thanks en help me!!!
lifebeginsat8000rpm
Re: newby
thanks :?
Luke
Post by Luke »
which errorcodes do you have?
do you have a wideband lambda meter?
do you know how to tune a car by yourself?
if not: take a tuner to help.
best regard from germany
Luke
lifebeginsat8000rpm
Luke wrote:which errorcodes do you have?
Luke
from the injectors the other i have to look
no i dont have a wideband lambda meter
i wil be goiing to the dyno in 2 months en now i am looking foor a good map so it wil last thos 2 months thanks
germany fry farren ?
Luke
Post by Luke »
you should try do tune without a wideband. that WILL NOT WORK!
you will damage the engine.
what do you mean with "fry farren"?
best regards Luke
lifebeginsat8000rpm
Luke wrote:you should try do tune without a wideband. that WILL NOT WORK!
best regards Luke
so i need a wideband somthing els to?
ent then?
Luke
Post by Luke »
buy a PLX (hondata recommends it) and plug it in.
how to do that you can read on the hondata homepages.
best regards Luke
lifebeginsat8000rpm
Luke wrote:buy a PLX (hondata recommends it) and plug it in.
best regards Luke
i have one from aem now
but i have 2 whires bleu en white ..... for dataloging.... help me ....how to conect to the s300
it reads verry lean in normal driving but pedal to the medel she is below 9
lifebeginsat8000rpm
i get the error code 41 i use a plug from a dead sensor ....
en now my laptop is fuckt by a can of coca cola :cry:
lifebeginsat8000rpm
s
i have a new laptop
bud the car gives code 41 & olsow baromitic pressor sensor & knock sensor to what is the problem....
Have you tried disabling the O2 heater?
lifebeginsat8000rpm
Spunkster wrote:Have you tried disabling the O2 heater?
yes i did
bud i have seen that 1 part on the ecu is burn even in my stock 1
i have 2 1stock 1with s300 en bouth gav the same problem
q31 it was i think is burnt
Q31 has nothing to do with the O2 heater. It is caused from swapping the plugs for the IAT and Purge valve.
lifebeginsat8000rpm
Spunkster wrote:Q31 has nothing to do with the O2 heater. It is caused from swapping the plugs for the IAT and Purge valve.
so it wil run with it? or do i have to put a now one in
