Anyone got a base for H22a Euro-R?
Posted: Mon Mar 30, 2009 1:44 pm
by doo0T!doo0T!
Anyone got a map for an H22a-R? SManager, S300,
Its a red-top, high compression, bigger cam version of the H22a with a single runner manifold like a b18c-R and a unique head. Not to be confused with the type-S which is different again.
I've tried a black top H22a program and it ran like shit.
Anyone?
Posted: Wed Apr 01, 2009 1:30 am
by cardinal811
Sway intake to a a USDM then come back
EURO R is now what you want, short eunner is cool and all but volume makes power.
GET RID OF THAT TRASH
Posted: Wed Apr 01, 2009 1:51 am
by doo0T!doo0T!
cardinal811 wrote:Sway intake to a a USDM then come back
Well for one you need to proof read your posts so you don't write nonsense.
And secondly what is so USDM about a dual runner manifold, every other market has them as well.
Just because it's called a Euro-R doesn't mean it's from Europe.
Get a clue and get some manners.
It's naturally aspirated so volume is less important than with yours.
Posted: Wed Apr 01, 2009 7:38 am
[abusive post deleted] Jeremy - I've given enough final warnings. I doubt this will be the first, nor last, time you are banned from a forum.
Posted: Tue Apr 07, 2009 8:33 am
by h22acivichatch
change injectors from 450 to 310s and adjuts overall fuel trim to -31. Im running a h22a euro-r as well
Posted: Tue Apr 07, 2009 2:42 pm
by doo0T!doo0T!
h22acivichatch wrote:change injectors from 450 to 310s and adjust overall fuel trim to -31. Im running a h22a euro-r as well
Thanks, is that just using the stock H22a map from the archive with adjustment?
What was your air/fuel curve like?
When you say change injectors do you mean physically change them or just change the injector size in SManager?, I'm guessing the latter.
Posted: Wed Apr 08, 2009 8:39 am
by h22acivichatch
Later. Change injector size in Smanager. My a/f curve is shot all to hell until i get my car tuned but it runs well right now. O2 Sensor is fried so i have to get a new one. Change overall fuel trim using calc function. Mine is 310 injectors -31 overall fuel trim. based off h22a base map that has 450 injectors.
Posted: Wed Apr 08, 2009 9:00 am
by Luke
@h22acivichatch: if i had a H22A-EuroR engine and would use your sollution... will you pay me a new engine if it blows?? :? surely not.
@doo0T!doo0T!: get it tuned propperly. with that you will archieve he best solution and won't risk a blown engine.
best regards Lukas
Posted: Wed Apr 08, 2009 1:38 pm
by h22acivichatch
luke well no i won't pay for your motor.
doot this is the set up i've been using for about 4 months, because i can't afford to get the car tuned. it is running a little rich at the moment but until i get a wideband put in the car and wired to the s300 im not worried. Plus everything in this forum is use at your own risk. I'll even post you a datalog of my set up and the calibration if your interested.
Posted: Wed Apr 08, 2009 1:54 pm
by doo0T!doo0T!
Thats ok, any ecu tuning is at your own risk.
i think thats enough to get me started anyway, my brother has a wideband I can borrow I think I'll just start with your set-up and road tune it myself while he drives.
I'm also going to try a 2001 ITR tune and play around with overall fuel trim and see how that compares.
I'm going to take it to a dyno but I'd rather turn up with a decent base than having them start from scratch, been there done that, I took my crx turbo in with no tune at all and it cost me $780 in dyno time.
Posted: Wed Apr 08, 2009 5:16 pm
by Luke
take care of the rev limits with the H22.
i think you shouldn't rev it so high like an ITR, as you want to use the ITR map as base.
best regards Lukas
Posted: Wed Apr 08, 2009 5:35 pm
by doo0T!doo0T!
^^ Yes definately.
having had one to pieces i can see now why they shouldn't be revved over the stock limit. They're big and heavy thats for damn sure.
Posted: Wed Apr 08, 2009 8:03 pm
by deafy
ITR timing map is going to be way different. I had tried a GSR map on my stock h22 and it ran horrible.
