Kmanager 1.3.5.4 not datalogging on return from hibernate
Posted: Wed Mar 25, 2009 2:59 am
by carbonctr
Hi
I have a CarPC screen in front of my dash that I use as a digital dash. The CarPC is set to hibernate when I switch off the ignition, so when I start up again it goes straight into KManager and shows my datalogging display.
With version 1.3.4, KManager started datalogging when the PC returned from hibernation, so I didn't need to click datalog myself.
Version 1.3.5.4 does not automatically datalog on return from hibernation, so I have to start it myself. Is there something I can do to sort this? Please bear in mind that KManager is already running so it is not a command line issue, even though I do already have datalog" at the end of my command line in the startup folder.
Posted: Wed Mar 25, 2009 7:58 am
Tested it out here and it works ok.
Posted: Wed Mar 25, 2009 8:38 am
by carbonctr
Hondata wrote:Tested it out here and it works ok.
I'll try re-installing KManager to see if it makes a difference. I was surprised when v1.3.4 did start datalogging automatically when returning from hibernation as I assume datalogging stops when the engine stops before the PC goes into hibernation in the first place.
Posted: Thu Mar 26, 2009 5:43 am
by carbonctr
I think it might have been because the last time I opened KManager I did not use the datalog command line command. I did re-install it last night, then opened KManager with datalog command parameter, hibernated, started CarPC and it datalogs on return from hibernation. Happy chappy :-)
