Question about a recent tune.
geoffrey70
Post by geoffrey70 »
- serial number of your K-Pro - Not sure, i can look if needed.
- KManager version (not 'the latest') - Not sure(Not tuned by me)
- the calibration (as an attachment) - ECU is locked
- what sort of vehicle you have - 2003 S2000
- what sort of ECU you are using - PRB
- anything about the car which has been modified from stock which may affect the ECU - Exhaust, test pipe, and the Kpro.
- a specific description of the problem-
I had my car tuned last friday. I've noticed that both of my fans are on when i turn the key forward and never turn off. Is this something that you can control with the Kpro? I'm wondering if i should take it back to the tuner and have it put back to normal? Thanks.
Without knowing the version of software used and a calibration and datalog showing the problem it is nearly impossible to give any advice on what should be done.
